Steam hot water
whi7723
Member Posts: 22
Live in Minnesota. Public utilities guy came and said I am using 3x the steam units and over 2000 gallons of water in 8 days. Prior month bill was the same. Said I had a hole in steam coil/trap. I pressure tested coil to 50lbs and no leaks. Also no buildup in coil. Water flows flows freely also thru trap. Any thoughts on what’s driving water usage and steam bill. Water must be going thru steam meter from somewhere I am guessing?
No other causes?0
Anyone?0
Maybe a more complete description of your setup would help.
Imagine you are describing the system to a blind person.
How is the steam useage measured, and what is the connection with the water meter-(condensate measurement?).—NBC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
