Need help identifying a part
rfenn22
Member Posts: 3
in Oil Heating
Hello, I work for a plumbing contractor in New Jersey. I have a customer who is looking to replace an oil fired steam boiler.I’m trying to figure out what this is does anyone know. I will attach a few more pictures
Looks like some sort of device designed to separate the water from the steam. Professor Dan mentions such a device in the Lost Art. Don't know if it's the same device or not. Can you make out the writing on the side ?0
@STEAM DOCTOR , you nailed it.
You should not need this with the new boiler, assuming it's piped correctly.All Steamed Up, Inc.
Consulting0 -
How does it work?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
It provides a "wide place in the road" that slows the steam velocity, allowing any water coming up with the steam to drop back into the boiler thru the small pipe coming out the bottom.
The proper way to do this is with a good header.All Steamed Up, Inc.
Consulting1 -
@rfenn22. Please do not trash. Many a sentimental steam man would be happy to take that off your hands.0
Check out unionsteam.com. They sell something called a steam separator0
I am sure that is not the original boiler. Should give some credit to the fellow that installed that boiler and reused it. Many would have scrapped it.0
Thank you for the help. If I get the job I’m sure it will be something we keep around as none of us knew what is was.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
