Boiler pumping the wrong way
Snowmelt
Snowmelt Member Posts: 1,457
I went to a job today, two zones, but the supply, which is usually on top of the boiler is being used as a return and the return as the supply, the pump was mounted inside the boiler jacket. I didn’t want to take the jacket off and investigate further, I was called just to change the zone valves.
    HVACNUT Member Posts: 7,204
    What boiler and model?
    Pics?
    kcoppSteve Minnich
  • lchmb
    lchmb Member Posts: 2,997
    so it's the direction of the zone valves or something else indicated it was backwards?
  • Snowmelt
    edited July 2018
    direction of zone valve, the placement of the purging ( ball valve and hose bib. when I turn the t-stat up and the heat went the same way the zone valves where facing. I am going to assume the pump was going in that direction also.
  • unclejohn
    unclejohn Member Posts: 1,833
    Old cast iron boiler? Never be a afraid to investigate. Where would Holmes be with that attitude.
    Steve Minnich
  • Snowmelt
    yes old cast iron boiler
    Some of the old boilers have the circ on the return inside the extended jacket. The Weil McLain pancake, York Shipley, American Standard Arcoleader, etc.
    delta TSteve MinnichRich_49
  • unclejohn
    Maybe who ever installed the zone valve in the first place didn't take the cover off either.
  • Snowmelt
    I would agree with you but when running the boiler it did heat in the direction of the zone valves
  • lchmb
    edited July 2018
    if they have no complaints over how it heats and how much fuel..I'd leave it.. Can fix it when they go with a new system..
  • Snowmelt
    That’s what I am going to do.
  • jumper
    jumper Member Posts: 2,499
    Originally one circulator was supposed to make hot water heating foolproof. So much simpler than steam. Nowadays hydronic schematics resemble spilled spaghetti.
