CREAKY KNEES
EBEBRATT-Ed
Member Posts: 19,411
Like everyone else in this business who has done this work for a long time my knees are pretty creaky. I have bad luck using a knee pad. I tend to leave it behind moving from place to place....like installing baseboard.
I have the usual strap on knee pads that are comfy to kneel on but the straps behind my knees are a killer. Tried a few pairs.
Anyone have a better solution or knee pads they recommend??
Duluth (work clothes etc.)
They had some bib overhauls with pockets for knee pads,
I have a pair of the bibs but the pockets just plain suck.
But the knee pads seemed pretty good.
They might have some work pants with those pockets.0 -
I got the same problem. But have to wear the uniform. So Duluth is out. Been trying to get the younger guys to get down more, and do more of the stand up work. But, I just have to down on my knees. Getting down is not the problem, its getting up is the killer. Even the equipment is getting smaller, can't sit on the bucket to often. The only brightside, is retirement isn't that far away. If I can make it.0
I've had good luck taping a couple layers of cardboard around my calves.
Doesn't bunch behind your knees.0 -
Hockey goalie pads.0
I have a pair, not sure of the brand though, that have about a 1" wide silicone strap. Since they are not the velcro style, they don't get wore out after a week of use. Also, I have found unless you are an east coast steam guy, the straps are so long I have to tie knots in them to take up the slack.
Either way, I have found if I just use the lower strap, it does not wad up behind my knee. Since I have found these with the silicone strap, I am more likely to use them more often. I just keep them in my bucket boss, and when I get to the job, I put them on before starting.
Rick0 -
I have been using these for a few years now and love them. The single strap does not hurt the back of my knee, and they are very comfy. The only issue I have is that they have a harder time staying in place, but if you are careful about exactly how tight and exactly where you put them on, they tend to stay pretty well
https://www.better-tools.com/product/leather-knee-pads/0 -
These knee pads have saved my knees:
https://www.amazon.com/gp/product/B000NCY3BW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I will forget that I have them on and when I go down on my knees, I brace for the pain which never comes.
The hard surface evenly distributes the weight across the knee.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
Working on cars, kneeing on pavement....... found an old 2 inch thick yoga mat being thrown out. Cut ~ 15 inch long section out of it, as single kneeing pad. Works pretty good.
Best pad I found was a black ~ 2.5 inch thick tough closed cell pad that came in some packing crate. ~ 15 x 24 inch. I used to be able to drop on it from standing position , no pain. And I killed my knees in my 30's kneeing on wood in attic installing insulation in floor.1 -
I'm too late. I've been working professionally with wrenches since I'm about 13 years old.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
@unclejohn had the answer like best LOL. But I am trying to get through one more year.
Thank you for all responses!0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
