Leak
brutus69
brutus69 Member Posts: 1
I have a leak in oil boiler. Leaks when hot water is called for. It has now stopped leaking after a week. It is very hot in basement and there is a smell. Waiting on new boiler. Turned this one off for safety. Any thoughts?
    Jamie Hall Member Posts: 27,237
    So far so good. Leave the old one that leaks off. What is the smell like? Oil? If the leak was serious, could it be a mould problem?
  • GBart
    GBart Member Posts: 746
    You might just need an expansion tank and relief valve, who said you need a new boiler?
