ANOTHER TT Indirect tank failed....
Javelin
Member Posts: 160
Heating Pros,
I just got back from a weeklong vacation to find my 2nd (a warranty replacement of the 1st) Tringle Tube Smart 40 leaking all over the basement. The well where the switch/sensor goes is filled with water, and the input/output of the boiler water seems all leaky with visible brown drips...
From what I know and the videos I've seen online, it seems like the OUTER tank is rusted through somehow maybe? Is this normal? Seems excessive that this is the 2nd TT tank failure for me..right? Shouldn't the outer tank last longer? its only filled with boiler water.... RIght? Any thoughts? this should be covered under the lifetime warranty right?
Thanks to all..
Jay
Thanks to all..
Jay
Yes it should be covered but you need to find the cause. They have a new tank design now called Ginius.0
Jay, have you contacted your contractor and have them contact the warranty department? Or Triangle Tube Tech support is open right now for your convenience and could assist you or your contractor with a path to resolution.0
The number for Triangle Tube Tech support is 856-228-88810
I understand there is a good chance the tank is leaking but I went through similar situation last year and the problem wasn’t a leaking tank. Instead, the drywell threads were leaking. I was able to unscrew the drywell, wrap the threads with loctite 55, and thread it back in. It’s been fine ever since. Check the threads before you replace the tank.DIY'er ... ripped out a perfectly good forced-air furnace and replaced it with hot water & radiators.1
- 116 Geothermal
- 169 Indoor-Air Quality
