Air to water heat pumps, anyone have feedback on makes
tim smith
Been looking at the Solstice extreme from Space Pak and the Aermec. Talked to John Siegenthaler who happens to be doing some evaluation for Solstice. He has one and used it through this winter and is quite impressed so far. Anyone have any current experience with these makes
I've been following Siggys system also. The Solstice uses heat from the buffer tank to defrost, instead of a resistance strip, that helps with efficiency. Works quickly also.
I'd say his temperature conditions this past winter were a good test of cold weather performance.Bob "hot rod" Rohr
Thermatlantic.0
this is very interesting as i want to reduce the carbon footprint for future generations"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Just be careful to consider where the electricity is coming from. If your heat pump can really return more than two and a half times the electricity it uses in the form of heat, then it will be a gain with pretty much any electricity source. However, if your return is less, and you are running from a natural gas, coal, or oil fired plant, you are actually producing more carbon, not less, as the power plant efficiency is so much less than the direct fired efficiency of a gas or oil fired hot water heater...newagedawn said:this is very interesting as i want to reduce the carbon footprint for future generations
Now if you are running from a solar, wind, or nuclear facility, that's not a problem, of course.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
