Rigid #700 Threader
Bob Gagnon plumbing and heating
Member Posts: 1,372
My Rigid 700 works great in forward, but in reverse the motor hums and trips circuits, the brushes look fine, could it be the switch?
Thanks, Bob Gagnon
Thanks, Bob Gagnon
If the motor hums, it's trying to turn but can't for some reason. Can you prop it over by hand both directions? I'd expect it to feel about the same resistance either way, without pipe in the dies. There might be something that binds in one direction only.
I wouldn't think the switch, or it'd trip instantly on a dead short.
@Bob Gagnon plumbing and heating
Check the "keepers" that hold the die in place. They are spring loaded. If one of them jambs up or brakes it can get jammed in the gears.
Seems to me I had that problem once1 -
It could be the switch, any poor connection will raise amp draw and these things DRAW on a good day.0
EBEBRATT, it works great in forward, just reverse is a problem..To learn more about this professional, click here to visit their ad in Find A Contractor.0
Can you turn the motor armature by hand (or maybe with a wooden dowel through an air vent)? I'm still imagining something binding the motor in reverse gear, like a shaft in the reducing gears that moves out of position during reverse operation and binds.
I suppose a really lousy connection on the reversing contacts in the switch could cause enough voltage drop that the motor couldn't start; that might have similar results. Does the switch sound\feel the same going into forward as reverse?
Had a 700 powerhead on a roll cutter drop a keeper like ebebratt-ed is describing. It would spin one direction and not the other0
@Bob Gagnon plumbing and heating what @GroundUp said. something to check. Seems to me those keepers can break off and allow rotation in one direction. Been a long time
I doubt it's the switch but it could be. Possible the switch is powering forward and reverse at the same time when in reverse.
I would take the drive end apart. As I remember nothing in there but gears and grease. Then you can get to the end of the motor shaft and see if you can turn it by hand before ripping the electrical apart. Probably the best way t go at it0
