Leaking pipe / fix now or wait for season?
Artfish1
Member Posts: 1
Hi, I have a very slight leak where a pipe is connected near the return on my steam boiler. Is there any benefit to getting it fixed now as opposed to waiting until I have the boiler serviced early fall?
Thank you!
Thank you!
Plus, if there are other issues might as well fix them too before the fall, or when it's very hot/humid in the basement.
Fixing the leak will require disassembling the piping to replace the leaking joint. That's going to be a chore - the large-size pipe may require a couple of burley plumbers, and potentially complicated by no unions shown in the picture. Who knows what problems might arise - fix it now.0
have the service done now..that way all the gunk from last winter doesnt have time to harden in.. and people arent as stressed from calls... they will do a better job..0
- 110 Chimneys & Flues
- 978 Plumbing
- 387 Solar
- 17 Recall Announcements
