Your advice on a Chiltrix chiller
RayWohlfarth
Member Posts: 1,834
I am looking to add air conditioning to the second floor addition of my home and need your advice. The space is heated with a baseboard and a cast iron boiler. I would like to use chilled water and was thinking of a Chiltrix chiller. Have you used one and your thoughts about it would be great. The load is about 1 1/2 tons.
Thank you for your expertise and guidance.
Ray Wohlfarth
Boiler Lessons
Boiler Lessons
It's nice equipment; similar to SpacePak's chiller. But for that small of a load, why not use standard ductless like Mitshubishi?Bob Boan
You would need 80 gallon or so of buffer, probably to prevent cycling the chiller?
What about the humidity?
Need a dew point control no doubt, or you could end up sweating. the heat emitters, not you personallyBob "hot rod" Rohr
@Ironman I was thinking of that but I was hoping to use hydronics as I sell my boilers against VRF every day LOL
@hot rod LOL I was thinking of using the wall mounted fan coils that look like the ductless mini splits.
Thanks Gentlemen
Ray Wohlfarth
Boiler Lessons0 -
I've heard the fan coils are noisier than a minisplit.--NBC0
If you go this route, don't forget that you'll have to fill it with glycol - in spite of what the instructions may say. If you lose power when it's cold, there's nothing to keep the HX and external piping from freezing.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.2 -
@Ironman Thanks They also suggested an electric heater. Thinking this may soon evolve into a larger than anticipated projectRay Wohlfarth
Boiler Lessons0
- 87.1K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
