Your advice on a Chiltrix chiller
I am looking to add air conditioning to the second floor addition of my home and need your advice. The space is heated with a baseboard and a cast iron boiler. I would like to use chilled water and was thinking of a Chiltrix chiller. Have you used one and your thoughts about it would be great. The load is about 1 1/2 tons.
Thank you for your expertise and guidance.
Ray Wohlfarth
Boiler Lessons
  • Ironman
    Ironman Posts: 7,942
    It's nice equipment; similar to SpacePak's chiller. But for that small of a load, why not use standard ductless like Mitshubishi?
    Bob Boan
    hot_rod Posts: 28,195
    You would need 80 gallon or so of buffer, probably to prevent cycling the chiller?
    What about the humidity?
    Need a dew point control no doubt, or you could end up sweating. the heat emitters, not you personally :)
  • RayWohlfarth
    RayWohlfarth Posts: 2,073
    @Ironman I was thinking of that but I was hoping to use hydronics as I sell my boilers against VRF every day LOL
    @hot rod LOL I was thinking of using the wall mounted fan coils that look like the ductless mini splits.
    Thanks Gentlemen
    Ray Wohlfarth
    Boiler Lessons
  • I've heard the fan coils are noisier than a minisplit.--NBC
  • RayWohlfarth
  • Ironman
    edited May 2018
    If you go this route, don't forget that you'll have to fill it with glycol - in spite of what the instructions may say. If you lose power when it's cold, there's nothing to keep the HX and external piping from freezing.
    Bob Boan
    GBartCanucker
  • RayWohlfarth
    @Ironman Thanks They also suggested an electric heater. Thinking this may soon evolve into a larger than anticipated project
    Ray Wohlfarth
    Boiler Lessons
