Steam Rookie
Member Posts: 4,434
Visited this boiler yesterday for a homeowner that wanted to replace it because it wouldn't fire. Tracked down a bad ignition control module and gave it another few years of life. Previous contractors had agreed that it needed to be replaced as they stood in the doorway to the room, not even trying to find out what was wrong with it.
But then I thought with all of the old safeties that may no longer work, maybe I did the homeowner a disservice. What do you think?
I've seen plenty of these 1920s-era boilers over the years but they've all had updated controls. This one looks original. Not sure this control system even meets Code anymore.
You'd need to replace the Pressuretrol, low-water cutoff and gas valve for starters. Also add a pilot safety to it if the original setup is not so equipped.
I think I'd recommend replacing it too. Be aware there is probably asbestos under the jacket.All Steamed Up, Inc.
Consulting1 -
what you did went a long way to build trust, now you fixed it, but time to bury that ole beast to something way more efficient, i thought all cali's were energy conscious,lol"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
- 109 Chimneys & Flues
- 975 Plumbing
- 387 Solar
- 17 Recall Announcements
