Slant fin Concept 21 gas valve
OK all you heating gurus out there ,apparently there are no replacement gas valves any longer for the Concept 21 boilers from Slant fin. I'm looking for a replacement, and i can't find 1 anywhere. I can't be the only one that has come across this problem. Slant Fin tells me , they have some fine new boilers and i should just replace the boiler !!!!!!! If you know of a place that can help me, please , let me know.... Thanks !!!!!!
    Steamhead Posts: 18,883
    What make and model is the valve?
    Semi-retired
  • coryb
    coryb Posts: 2
    The valve is a Robertshaw-Grayson
    7200DERN
    1/2 in 3/4 out
    straight through valve
    no pilot
    2 wire, 24 volt
    full wave, (what ever that means )
    That appears to be a negative-pressure valve. Not sure who else makes them. If you're not a pro, best to call one.
    Semi-retired
  • Mad Dog_2
    Mad Dog_2 Posts: 8,740
    Ask Timmie Mc Elwain. He'll know the exact one,
    Cory. Are you a licensed plumber? Every municipality I know of requires a Master Plumber or gasfitters license to work on those. Mad Dog
