Slant fin Concept 21 gas valve
coryb
coryb Member Posts: 2
OK all you heating gurus out there ,apparently there are no replacement gas valves any longer for the Concept 21 boilers from Slant fin. I'm looking for a replacement, and i can't find 1 anywhere. I can't be the only one that has come across this problem. Slant Fin tells me , they have some fine new boilers and i should just replace the boiler !!!!!!! If you know of a place that can help me, please , let me know.... Thanks !!!!!!
    Steamhead Member Posts: 18,438
    What make and model is the valve?
    Consulting
  • coryb
    The valve is a Robertshaw-Grayson
    7200DERN
    1/2 in 3/4 out
    straight through valve
    no pilot
    2 wire, 24 volt
    full wave, (what ever that means )
    That appears to be a negative-pressure valve. Not sure who else makes them. If you're not a pro, best to call one.
    Consulting
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,537
    Ask Timmie Mc Elwain. He'll know the exact one,
    Cory. Are you a licensed plumber? Every municipality I know of requires a Master Plumber or gasfitters license to work on those. Mad Dog
