Smiths heating edge baseboard cover removal...
john p_2
Member Posts: 367
in Gas Heating
Installing some Smiths heating edge baseboard and believe there will be issues if I place my base molding up against the end caps - I don"t believe I will be able to ever remover the covers unless I remove the molding first ?!?! Am I wrong?
Thanks, I knew someone here would know for sure. Didn't want to install molding untill I was sure the covers could be removed.0
- 116 Geothermal
- 15.8K Strictly Steam
