Smiths heating edge baseboard cover removal...
john p_2
john p_2 Member Posts: 367
Installing some Smiths heating edge baseboard and believe there will be issues if I place my base molding up against the end caps - I don"t believe I will be able to ever remover the covers unless I remove the molding first ?!?! Am I wrong?
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,290
    You can remove the covers from the front by carefully prying the lip out from behind the fin tube block.
    Ironman
  • john p_2
    Thanks, I knew someone here would know for sure. Didn't want to install molding untill I was sure the covers could be removed.
