urinal with internal p-trap
Total1
Total1 Member Posts: 44
I'm buying a used urinal with internal p-trap , from the back out the urinal is is 1 1/2 inch abs . Do you need another p-trap or run it directly into the main plumbing stack ? Thanks people . ( great forum here )
  • Total1
    this is what the urinal looks like .
    Steamhead Member Posts: 18,516
    I doubt it needs a separate trap. You might want to check with the manufacturer. But whatever you do, don't p**s off the plumbing inspector :D:D:D (couldn't resist)
    Consulting
  • Ironman
    Ironman Member Posts: 7,904
    Just like with a water closet, the internal trap is all that's required.
    You'll need a urinal flange, gasket and bolts to connect it to the waste line.
    Bob Boan
  • Total1
    thanks , All installed with one p-trap . It is better to P*ss off a plumbing inspector than to p*ss on one ,, LOL ,,, The urinal is working awesome ...
