replacing steam radiator
rdema19403
Member Posts: 5
my wife friend has an old steam radiator what are the option replacing it with something newer than the one in this image i am posting
Thanks in advance
Thanks in advance
Main thing is to try and find one at least approximately the same size. One can buy new ones, although they are a bit pricey, but depending on where you are there are usually recycling places and junkyards which may have them, and they often turn up on Craigslist.
How on earth did it busted like that?Br. Jamie, osb
no idea is does it have to be replaced by the same type of radiator any ideas if their is something newer it can be replaced with0
No, it doesn't have to be replaced with the same type -- but unless you know that the old one was either too big or too small for the space, it would be wise to pick one with more or less the same capacity.
You will probably have to replace the trap and valve anyway, unless you get really lucky and manage to get the old spuds out without damage and they fit the new radiator.Br. Jamie, osb
That looks like freezing damage- is this a steam or hot-water system?All Steamed Up, Inc.
Consulting2 -
That's what I thought, too -- but the OP says steam, so...Steamhead said:That looks like freezing damage- is this a steam or hot-water system?
It may have been turned off at the valve, and had thus filled with water, and frozen.—NBC0
I have seen a lot for radiators damaged by freezing. They almost always crack along the rib of the section. I have never seen one crack like this. It looks like hammer damage to me.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
I have. It's just a matter of where the weak point is.Dave in QCA said:. I have never seen one crack like this.
Consulting0 -
i was wondering what could it be replaced with that is old technology any ideas what it could be replaced with or what is available? it is a hot water system
Thanks in advance0 -
If it's replaced with a radiator of ± the same size (we can help check the sizes), the problems should be fairly straightforward. If the type of heat is changed (e.g. to baseboard), there will be significant issues that will need to be considered before-hand: an contractor experienced with hydronic work will need to be consulted.1
the dimensions
are 36inches x 28 x 10 inches0 -
A common enough size... depending on where you are, many scrap and salvage yards have radiators. Which you have to check for leaks. You can also purchase brand new ones, but they are more expensive, naturally.Br. Jamie, osb
could you something like this to replace it?
Sure. Just make sure that the EDR ratings are similar.Br. Jamie, osb
- 120 Geothermal
