Drain Pan Heater ?
2»
  • GW
    GW Member Posts: 5,152
    Wow that seems like a lot. Although I buy line sets in 164 foot rolls. So I lose track of costs, sort of.
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • clammy
    clammy Member Posts: 3,250
    Rob just a heads up .I personally don t use tray wire for mini splits anymore .I have gotten shot down by our electrical inspectors so now we use a rubber coated metallic mc type cable thats approved to run threw interior walls and threw attics or crawl spaces which tray wiring isn t 'We learned the hard way and so did a larger hvac company who did a very large vrf system ouch ,there water tight fitting are not cheap and on multi head units you will need to greenlee another knock out to your 3 control wires ie 3 head unit.Just show ur post peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
    NY_Rob
  • NY_Rob
    NY_Rob Member Posts: 1,370
    ^ Thanks Clammy....
    Funny you mentioned the tray cable...
    Upon inspecting the three linesets that arrived Thursday- it just so happens that the linesets were a little more $$ because (unbeknown to me) they included a "rubber coated metallic mc type cable thats approved to run threw interior walls and threw attics or crawl spaces" that runs the length of the copper lineset Plus an additional 5 ft.
    Since I have that now.. I plan to return the three 50' rolls of tray cable I bought.
    Here's the lineset and cable...
  • clammy
    Good for you buddy ,i usually use a regular mc cable connector for the indoor unit the approved outdoor connector is huge .Those line set are a vast improvement over armoflex insulation .I wish i could get that type of insulation for my regular ac line set not a pre insulated line set just the insulation Not a huge fan of pre insulated line sets in larger pipe sizes i see alot that where kinked by installers the insulation hides that crap plus usually they just jamming that stuff .peace and good luck clammy
    NJ Master HVAC Lic.
    Mahwah, NJ
  • NY_Rob
    Two of the three lineset runs will be pretty easy/straight forward.
    The third run (about 42' total from end to end) entails a 20' section running inside a soffit... with a bay window in the middle of the run. Fun times! :'(
