Noncondensing Combi?
GW
Member Posts: 5,068
Anyone got any ideas on a combination boiler, noncondensing? I have a condo/apartment situation. No way the drain anything.
Can’t treat the condensate and pump it up?0
Doesn't Utica have something?0
I don’t know, between the lack of replies here and FW Webb Co. saying they don’t have anything, I told the property owner to go with the condensing unit or keep tracking down Plumbers. I tossed out a random number for condensing unit in a conversation and not too long after that.0
Embassy had the Axia boiler but discontinued.
They replaced w/ this....
http://www.embassyind.com/celsior
Utica has the CuB series. It's a Non-Condensing Wall-Hung Combi. They also have a Heat-Only version.
The Peerless EC has an optional hot water coil. We fire them with a Midco Gas burner, though oil is OK too.To learn more about this professional, click here to visit their ad in Find A Contractor.0
Thanks all. It's in a bathroom so we would need a sealed unit.
Bob, thanks, I somehow didnt see your reply until later last night.
That Utica looks good, and PlimntonHills has it, they said they can get it to me today! wow0 -
OK I take that back, Monday 1st thing.0
It's going in a bathroom and you can't get the condensate line to a drain? *scratches head*GW said:Thanks all. It's in a bathroom so we would need a sealed unit.
Somewhere I've got a pic of a vinyl tube sillyconed into a p trap. There were water stains under it for some reason.0
Condensate drain into the bathroom sink? It’s a wall hung lavatory with chrome P-trap. Sure, I can do that. It would look disastrous though. If the sink was mounted on the wall where the boiler is, I wouldn’t be going through this whole process.
So my new problem is the new boiler is 150k and the old one was 105k. I looked at the gas line and it's too small. That created other costs.
I just learned the the other plumber will do the job; not sure what boiler he has in mind.
Thanks for all of the comments0 -
Thanks Ed yes the Utica non condense looked sweet, but the gas pipe is small and another plumber slipped in the back door. I'm cool, we have work!0
Curious.... what is/was there for a 105k btu combi?0
I’m in the same situation, maybe they installed an indirect water heater, I want to try the combi cub from Utica myself. Does anyone have any pics of the combi cub in action.0
I installed one Cub...
Not overly impressed... lots of plastic parts inside.0 -
This was th old unit, no idea what it is0
That's the old Burnham Minuteman 2 unit. Their answer to the Heatmaker0
I think in your attempt at simplicity, you’re actually complicating things @GW. If you’re installing this in a bathroom you can figure a way to drain the condensate, I believe in you!0
Now that I’ve caught up on the comments, I believe in you for the next job0
Yes draining is always possible but how ugly is another topic. Unless some plumbers out there have some pixi dust they sprinkle on their pipes, I’m not sure what magic can be used for this 3rd floor apartment bathroom. Apparently there was a kitchen below the bathroom so not even a clean way to route a pipe to the basement
I thought about the heat maker but I don’t have great feelings about that unit.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
