minerals in water
smklin
smklin Member Posts: 69
I have a few TT boilers that have heat exchangers going bad in them . I did but in glycol when I started up the system . Can glycol and mineral in water react to make them leak ????
    Jamie Hall Member Posts: 27,385
    Not the combination. But minerals -- if there are enough of certain ones -- can ruin a boiler astonishingly quickly. It is best to use deionized water for your initial fill if there is any real concern about the water quality.
  • smklin
    I am in a area that has high mineral content .DEIONIZED WATER would RO water work
    Yes.
    Canucker
  • kcopp
    kcopp Member Posts: 4,682
    When you say "going bad" please explain... What is the entire system have for components? Which boiler?
  • HomerJSmith
    HomerJSmith Member Posts: 2,779
    edited April 2018
    Reverse Osmosis will take you a while to do and your cartridges and membrane must be relatively new.
    What minerals can do is shorten the life of the additive package in glycol, which is why you use DI, RO, or distilled water.
    Chlorine is a no, no, but where is the leaking happening? Too much mineralization can build up on the HX and may create hot spots which may weaken the tubes.
    Water quality is becoming a big issue with the newer boilers, especially with glycol.
    hot_rod Member Posts: 27,484
    edited April 2018
    Leaks at the welds?
    Chlorides in high levels can be a problem on stainless boiler. In the manual they give you an acceptable range for TDS and chlorides typically.
    I have not found many places in the US where tap water is adequate quality for hi-efficiency boilers. Either treat the water DI or RO, buy treated water, many water treatment suppliers have RO or DI water to purchase, or use pre-mixed glycol.
    Here is a handful of boiler water specs. Viessmann, in the center has a different spec as the boilers increase in size. 2 PPM on larger boilers, that's not commonly found water :)
  • smklin
    The heat exchangers start to leak in them .It has triangle tube boilers, aquatherm piping, grundfos pumps .
  • AdrianeGray
    AdrianeGray Member Posts: 2
    Several minerals commonly found in the tap water are:
    Calcium, Magnesium, Sodium, Potassium, Phosphorus etcetera.
  • Zman
    Zman Member Posts: 7,609
    @AdrianeGray
    Are you visiting this site in order to learn English?
    Your other post https://forum.heatinghelp.com/discussion/165334/which-heating-system-is-the-best-for-home#latest
    Albert Einstein
