in floor hydronic heating system design
rich48
Member Posts: 4
I was wondering if anyone knows of information or where i could get good information on how to design an in floor radiant heating system for my house. Its a ranch house being built this summer and the basement cellar will have in floor heat also. thanks!
Will you be doing this yourself or will you have the plumber do it ?
Where are you located ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
How informative do you want? Modern hydronic heating is very much an engineers approach to hydronic design.0
I will do that thank you very much!0
As much as I love Modern Hydronic Heating, it is overwhelming to those who don't already have a strong math background and some expertise in the field.
I would start with this one from this sites founder https://heatinghelp.com/store/detail/hydronic-radiant-heating-a-practical-guide-for-the-nonengineer-installer"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
I just want information on where to look or who to get ahold of to get an idea of how to properly build an in floor hydronic system with all the correct components.0
The first thing you need is to do an ACCURATE, SCIENTIFIC heat loss calculation like an ACCA Manual J or equivalent. This is THE foundation for designing everything. Without it, you don't even have a target to shoot at.
As far as designing it yourself: if you're not mathematically and scientifically inclined, I would not recommend it. Even if you are, without trade experience, I wouldn't recommend it.
There are some very capable designers on here, including Rich McGrath and Zman. I'd highly recommend contacting one of them. That way, you'll get it done right and have the opportunity of learning at the same time.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
No , don't ignore the math . DO THE MATH .HomerJSmith said:Just ignore the math, I never really understood it either and I read the book 4 times. It is much more than adequate to tell you how a system should be put together. But...the more information you have the more successful you will be, so, go with Zman's recommendation, too.
732-751-1560
Rich McGrath 732-581-38333 -
Rich, don't get your knickers in a twist, it was a joke.
I know that Zurn, Wirsbo(now Uponor), and Rehau have design books with nomograms that do the math for you. You may find these online. They are packed with radiant heating design criteria and more easily understood.
http://www.zurn.com/media-library/web_documents/pdfs/zpm02101-pdf.aspx
https://www.uponorpro.com/~/media/extranet/files/manuals/heating_hb99_rprnt10-7.ashx?version=062220160829
http://viewer.zmags.com/publication/9c73a879#/9c73a879/52
It all starts with a zone by zone whole house heat loss calculation.0 -
Another option for some learning. Technical journals broken down into bite size pieces. Start with the Fundamentals issue #12 and jump around to the others that apply to your quest for information. Quick reads, lots of pictures and product options. PDF or hard copies available.
I have back issues if anyone is missing some.
https://www.caleffi.com/usa/en-us/technical-magazineBob "hot rod" Rohr
Living the hydronic dream-1 -
I wish Caleffi would print the Idronics magazine without legs, they always seem to walk off.0
