See what we found on a job?
RayWohlfarth
Member Posts: 1,702
Customer complained of headaches. This is what we found above the drop ceiling in the return air plennum
Ray Wohlfarth
Boiler Lessons
Boiler Lessons
Scary.
I have seen a lot of flue pipes that are not secured well enough for me, not enough screws and no hangers.
It may stay up fine during normal operation.
But,...............will it stay up if you get a puff back?
That's my criteria0 -
So the smoke pipe goes thru the return-air plenum? Whoever did that should not be in the business.All Steamed Up, Inc.
Consulting1 -
Open plenums are disgusting and should be outlawed . Run ducts or figure something else out . Good thing you found this Ray , good jobYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
@STEVEusaPA We were there to look at installing an AC unit.
@ratio That was my reaction when I saw this LOL
@EBEBRATT-Ed We were told this did not work and then it started while there.
@Steamhead I agree Some people are real hacks.
@Rich Thanks. Return air plennums are dangerousRay Wohlfarth
Boiler Lessons0 -
Seems that no one knowns that they should be installed a single wall to double wall appliance adapter .Even on jobs i see inspected they never use them and when i do a job w permits the inspectors always look at the adp strangely and i tell them what it is and they usually say they never seen one funny cause that what is supposed to be used to prevent what rays picuture posted . great find ray its sad that some many have no idea of what there doing or more don t care and wouldnt spend the 46 dollars on the correct adp.peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
They were fortunate they could still complain... dead men don't get headaches.RayWohlfarth said:Customer complained of headaches. This is what we found above the drop ceiling...
No CO detectors in the building?
@clammy Right! How much extra would a proper adaptor cost in the scheme of things.
@NY_Rob Great point No CO detectors in space.Ray Wohlfarth
Boiler Lessons0 -
Most all commercial buildings have return air plenums. Your not going to change that.
As far as the fluepipe in the RA plenum it doesn't sound like the best idea.....................Return air plenum is not supposed to contain any plastic, pvc piping, or plastic covered wiring Romex etc.
Conduit, greenfield, mc cable anything metal is ok.
Flue pipe doesn't seem right but I am thinking it meets code. Have to look that one up0 -
A return air plenum has the potential to be at a lower static pressure than the flue. The only flue that should be allowed through the plenum is one that has no joints inside the plenum, and has welded seams.0
We had a building with one woman who was constantly complaining of being light headed and dizzy and insisted it was because the boiler exhaust was leaking. I went out and checked the flue, the chimney, and checked combustion on the boiler. Everything was good. I checked back with the building maintenance a few weeks later and the lady was in the hospital. She was having heart attacks.Never stop learning.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
