Which is it: "ignitor" or "igniter"? Discuss.
JohnNY
Member Posts: 3,324
Or are those terms and spellings simply interchangeable?
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
IGNITOR
IGNITOR is the Italian name for a nuclear research project of magnetic confinement fusion, developed by ENEA Laboratories in Frascati. Construction (in Russia) is not complete. The project theory is based on ignited plasma in tokamak.
Wikipedia
[iɡˈnīdər]
NOUN
igniters (plural noun)
1] a device for igniting a fuel mixture in an engine.
2] a device for causing an electric arc.
Wikipeda had no definition for igniter.
Are you talking about gas or oil? For oil I say igniter. Spell check seems to dislike ignitor.
Are ya snowed in today @JohnNY ? 4th Bore'Easter for us in the Philly area. Started at 5:30, dug out my house, my fathers house, just finished the shop...now I have to go to work. Snow...grrrThere was an error rendering this rich post.
I feel igniter is correct. Compare to other examples such as lighter, chopper, fryer, opener, seller, mulcher etc.....
Not a linguistics expert by any means, but usually there are patterns for such things. Though in English the exceptions usually outnumber the rule so......
manufacturers can't even agree with themselves! Its both ways on the same page
https://customer.honeywell.com/en-US/Pages/Department.aspx?cat=HonECC+Catalog&category=Igniters+and+Sensors&catpath=1.1.30
For what it's worth I always spelled it as ignitor. Spell check always changes it to igniter. I believe both spellings represent the same thing, wether it's a hot surface ignitor or an electric igniter for an oil burner. Either way it's a device that that produces ignition.
I've always wondered about this subject myself.0 -
It's kinda like this: I work a lot in Staunton [pronounced STAN ton] VA, but my father's sister is my aunt [pronounced AWEnt]. That's the way it's pronounced around here. But folks that aren't from here pronounce the two words the exact opposite.
I spell it ignitor, but I'm also a contractOR.Bob Boan
I believe Ignitor is the person who does the igniting and Igniter is the object which does the igniting. So unless you are replacing the person who lights the boiler you should use the "or" Just my opinion
Ray Wohlfarth
Boiler Lessons2 -
Websters has it both ways as a noun. Then it also has ignitible and ignitable although the first spelling shows a misspelling on this site.0
I would think the correct spelling would be "Igniter". The magic "e", serving to turn "i" into a "Long Vowel".
Not saying I always spell it that way, though.0 -
I think it's something like Robertshaw = ignitor , Honeywell = igniter or vice - versa.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
spark plug0
After they pahk da cahh.ChrisJ said:As long as people know what you mean I don't think it matters. Don't people in your area eat with a fawk?
2 -
That's not BrooklynSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
-1 -
That's not BrooklynThere was an error rendering this rich post.
Bawston.0
Classes0 -
For what it is worth Honeywell spells it with "ER".0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
