Testo Smart Probes
GBart
Member Posts: 746
Has anyone tried any of the Testo Smart Probes yet? We have the Refrigeration and VAC sets, they are fantastic. Very easy to use and figure out and assign roles.
I use the refrigeration set and two 605i thermohygrometers. They work well and are really convenient. I don’t have to drill as many holes and it’s easy to capture and share the data. The trend graph feature is really nice too. Quicker, easier measurements make for quicker and more accurate diagnosis.1
Yeah I'm impressed, plus you don't have to worry about losing much charge in the hoses because there aren't any.0
Regarding refrigerant loss... I ended up buying a set of stubby hoses with ball valves. I can’t get the probes into some tight spots, and the Testo Schrader depressors are a little too long. The Yellow Jacket hoses I got are female on one end and male on the other and only 6” long.0
Do you have to have Location turned on to use the Testos? The last set (I forget the brand) I looked at required GPS to be on to use them, the app wouldn't even start without it.0
