What is it? Your guess is better than mine.
the_donut
Member Posts: 374
Any guesses on what this tool was used for? Background: found this in a late 19th century apartment near a drain.
Edit: didn’t realize this posted to radiant, thought I was posting to main. My mistake.
Reminds me of a split pipe hanger.
Lag screw that looks too short.
Would maybe have to maybe slip pipe thru after screwing in or slip ring over pipe then spread to tighten on ball??
If a hanger, it looks to be a PIA and glad to not to have to use them.
It is clay tile sized.0
Looks like a hanger to me0
It is. The ball joint allows some movement.All Steamed Up, Inc.
Consulting0 -
I have some in the basement of the main place I care for... still holding up pipes.Br. Jamie, osb
Good to know. Thank you gents.0
