The worse steam coil repair thus far
lostinheating
Member Posts: 31
Boy when it rains it pours. Had to fix a leaking steam coil at the adapter fitting. Iron pipe going into copper. The pipe never comes out easy so I have to redo fitting and run copper. Previous mechanic Jimmy rigged it and when pulled off old fitting everything was trashed. Had to make a new piece for adapter to fit. Had to do it for supply and return. This job was so bad I had to brass my adapter an me and female to each other because they wouldn't come apart after measuring.
ya gotta do what ya gotta do.
But if it was me, I would braze the stub into the header and after it cools sweat the adapter on.
Once you heat and aneal an adapter they get so soft they stretch when you crank a threaded pipe into it.
Looks good that stuff is tough takes some experience and creativity.0 -
Nice work. I've got a few that're more silver then not at this stage. I'm afraid I'm going to have to replace it the next time it fails.0
That's a good idea but I actually love brazing over soldering.0
- 120 Geothermal
