The Ouch Factor
HeatingHelp
HeatingHelp Administrator Posts: 718
edited March 2018 in THE MAIN WALL
The Ouch Factor
Learning about conduction the hard way.
Read the full story here
b_bz
  • BradHotNCold
    BradHotNCold Member Posts: 82
    My plumber checked for a hot wire by touching the hot? wire with his index finger and a neutral wire with his thumb. When I exclaimed he could get electrocuted, he said no, as the current wasn’t flowing through his heart like it would if he touched the hot? wire with his right hand and the neutral with his left. He is still with us, but I don’t follow his example, even though I have been known to do my own wiring from time to time.
    Jamie Hall Member Posts: 26,838
    Got to admit I use the hand on the pipe trick to check for a trap which is open which shouldn't be... I'm not as good as your old timer, but I can usually tell the difference between hot condensate (ouch!) and steam leaking (YEOUCH!).
  • GW
    GW Member Posts: 5,137
    edited March 2018
    Great story!
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
    Erin Holohan Haskell
  • fixitguy
    fixitguy Member Posts: 99
    The Doctor, noticing the scars on my forearms asked ,"do you use drugs?"I had to reply, "yes, but that's not where those scars came from" Badge of honor for a master.
    Steamhead Member Posts: 18,205
    edited March 2018
    @Dan Holohan calls this the "Ah-Ha-Ha Test for the Presence of Latent BTUs".
    Consulting
  • GW
    https://photos.app.goo.gl/NTWqAXbvwHdkNeCL9
    It’s me, can’t quite really prove there are no additives on my fingers. This was a breeze, didn’t have to squirm at the end
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • NY_Rob
    NY_Rob Member Posts: 1,370
    I think the smoke we see in the video is coming from your skin :#
  • GW
    Lol no that was easy 😄
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
