Mobile home furnace
BigBubba83
Member Posts: 3
in Oil Heating
Hello I live in a trailer and the furnace turns on and spills a little diesel out very small amount and u can smell diesel smell for a short time I just replaced the electrodes and nozzle as well as fuel pump and the motor worked fine for a while and then started leaking a little bit when it first turns on any advice on this would be appreciated thanks
Where does it spill the fuel? Into the furnace? Delayed ignition? Could be a igniter/transformer problem.0
Leaks out the bottom of the main housing I got it shut off right now but it also smokes some when it first turns on I dont think so on delayed ignition will look later when I have time but I don't believe it is0
You'll have to check a few things from simple to complex
1. Make sure all fittings are tight, especially unused plugs in the pump, and the bleed fitting.
2. Check your Z dimension.
3. Make sure nozzle is on tight, but not too tight.
4. Fully check the fuel pump with gauges-pressure, vacuum, cut-off.
If all of that passes, I'd want to see combustion numbers. I'd next check for a cracked heat exchanger.
I'm leaning towards the fuel pump.There was an error rendering this rich post.
Ya that's what a friend said was just replace beginning of the winter though don't want to change it again lol0
Check number 1. in @STEVEusaPA 's post. If it was replaced recently, I'd be looking for a leak as he suggests.BigBubba83 said:Ya that's what a friend said was just replace beginning of the winter though don't want to change it again lol
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
