Sodium Silicate short term boiler leak remedy?
razzor
razzor Member Posts: 20
Still trying to make it to April with leaking Burnham boiler. 2” horizontal crack in center section. Does anyone have any thoughts on sodium silicate or water glass as a way to stop or at least slow down the leak?
Thanks.
    Jamie Hall Member Posts: 25,726
    Might work. Might also gum up a lot of other bits of your heating system, too.
  • Is the crack above or below the waterline?
    For below the waterline leaks, some old time remedies for this were to put a cup of rye seeds into the boiler. As they are so hairy, the seeds would jam into the hole, and stop it up-they said.
    Radiator stop leak was another fix, but the smell was awful!—NBC
  • newagedawn
    newagedawn Member Posts: 586
    try some really good silicon caulk, i've had success with that before
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
  • razzor
    Thanks. Hot water boiler so I guess below the waterline? Can you recommend a good high temp silicone sealer? Also thoughts on JB Weld or another epoxy?
  • newagedawn
    whatever works and what ever gets them to spring, never tried jb weld, try it
    hot_rod Member Posts: 24,668
    I have used the Fernox products a few times with success. I'd suggest against the automotive type radiator sealers, use some product designed for hydronics.
  • Grallert
    Grallert Member Posts: 928
    I've used Pure Pro Boiler Weld Liquid with great results on water boilers. The success rate for me has been near 80%.
    Get it at F.W.Webb
