Boiler Feeder Check Valves?
Major7
Major7 Member Posts: 44
Greetings:
I'm about ready to repipe my boiler feeder, since the dielectric unions were not installed in the right place by the contractor (before I purchased the house). My question is simply this, is a check valve required, and if so, what if any type venting mechanism is required? My home is in the US.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,197
    Yes an back flow preventer is required. on any boiler feeder connected to the water supply ...
  • Dialectric unions can be the gift that keeps on leaking, due to cheap hose washers.
    Many people think a brass, or bronze transition fitting, like a ball valve is more reliable, and seems to cut down on the galvanic action.—NBC
    kcopp
  • Major7
    thanks for the feedback. Is a check valve a suitable backflow preventer?
  • Check your local code. Here in Omaha, we would need a testable backflow, even though I have a spring loaded valve on the feed. The backflow must also be checked for operation yearly, but your requirements may vary in your location.—NBC
  • JUGHNE
    JUGHNE Member Posts: 11,413
    Nicholas, is that a city of Omaha or state of NE requirement.
    Is annual testing/certifying required?
    Our small local water dept says boilers must have a testable BFP.
    Most of the pictures we see (other states) here have only the double check air gap BFP installed.
  • Good question-the inspection requirements are administered by the MUD, by request of the Feds.--NBC
    SuperTech
    Jamie Hall Member Posts: 26,005
    Generally speaking, a check valve is not acceptable as a backflow preventer -- and honestly even if it were I wouldn't accept it on my own plumbing, nor ever install one on someoneelse's.
  • STEVEusaPA
    Put this on, valves on both sides, add low water cut-off (if you don't already have it) and be done with it.
    SuperTech
  • JUGHNE
    But is it testable?.....I think not.
    Is it adequate protection......I think so.
  • kcopp
    kcopp Member Posts: 4,555
    Do you need the 1156f if its a steam boiler.... the 9d should suffice.
    EBEBRATT-Ed Member Posts: 17,772
    9D is fine in MAss unless you have glycol or chemicals in the boiler. I'm not a plumber but that's what plumbers in our shop told me
