Oddball steel fitting
the_donut
the_donut Member Posts: 374
Anyone know what this fitting is called? I’ve spent too much time thumbing through grainger catalogs. It’s a combi drain for 2 apartments with the top outlet feeding into a sink then vents.
  • j a_2
    j a_2 Member Posts: 1,804
    IDK But it looks like a tapped TY on it back.. a tapped TY is normally used on the vertical to pick up a sink of sorts
    HVACNUT Member Posts: 7,233
    Cross Wye?
    hot_rod Member Posts: 26,599
    Looks like a San Tee. A vertical drain should tie into a horizontal run with a wye or combo fitting.
  • Fred
    Fred Member Posts: 8,542
    edited February 2018
    It's a Double Wye or a double Tee.
  • the_donut
    Back rotted out from standing water. We are planning to use a y adaptor, a combi San tee with sweep 90, 90, and ferncos after cutting old fitting out.
  • Fred
    Looks like one of those jobs that when you're done you'll say "I should of done it differently".
    SuperTechdelta T
  • EzzyT
    EzzyT Member Posts: 1,377
    That fitting is called a side outlet sanitary tee or could be a side outlet sanitary wye
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • the_donut
    Not a whole lot can be done. I have to meet those pipes and all are buried under 6” of concrete, brick, and mortar. I would have preferred if the apartments didn’t share drains and the tubs weren’t kissing each other at the drains.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    All of this delicious knowledge shared, and in just an hour. Gosh.
    Thanks!
    Retired and loving it.
  • Danny Scully
    Danny Scully Member Posts: 1,465
    I would say that’s a 45 vented tub wye. It’s available in no-hub.
  • gerry gill
    gerry gill Member Posts: 3,083
    well, i know what i would call it >:)
    gwgillplumbingandheating.com
    SuperTechrick in AlaskaSolid_Fuel_Man
    EBEBRATT-Ed Member Posts: 19,598
    Perfectly happy with my 9 licenses and none of them are plumbing!!
    (This is intended to be a compliment to all the plumbers)
