Oddball steel fitting
the_donut
Member Posts: 374
Anyone know what this fitting is called? I’ve spent too much time thumbing through grainger catalogs. It’s a combi drain for 2 apartments with the top outlet feeding into a sink then vents.
IDK But it looks like a tapped TY on it back.. a tapped TY is normally used on the vertical to pick up a sink of sorts0
Cross Wye?0
Looks like a San Tee. A vertical drain should tie into a horizontal run with a wye or combo fitting.Bob "hot rod" Rohr
Living the hydronic dream0 -
It's a Double Wye or a double Tee.0
Back rotted out from standing water. We are planning to use a y adaptor, a combi San tee with sweep 90, 90, and ferncos after cutting old fitting out.0
That fitting is called a side outlet sanitary tee or could be a side outlet sanitary wye0
Not a whole lot can be done. I have to meet those pipes and all are buried under 6” of concrete, brick, and mortar. I would have preferred if the apartments didn’t share drains and the tubs weren’t kissing each other at the drains.0
All of this delicious knowledge shared, and in just an hour. Gosh.
Thanks!Retired and loving it.0 -
I would say that’s a 45 vented tub wye. It’s available in no-hub.0
well, i know what i would call itgwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.3 -
Perfectly happy with my 9 licenses and none of them are plumbing!!
(This is intended to be a compliment to all the plumbers)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
