Increased Electric Bill
EricGill
Member Posts: 2
Installed a brand new Lochinvar NKC110 the end of October. I don't use it very much for heat but more for hot water. My electric bill this December showed 105% more usage than last December. I have no idea what I had for a boiler before but it was old and not very efficient. I understand that this year was colder but 105% seems a little crazy. Has anyone experienced this? I am not a plumbing or electrical expert at all so please try to keep the technical jargon to a minimum.
Thanks
Thanks
Well... since that boiler isn't electric, and uses relatively little electricity to run... I doubt that it was the boiler change. What else in terms of usage has changed?Br. Jamie, osb
Have you studied the bill to be sure the charge is based on measured usage for the month. Often the meter does not get read and they estimate usage, only to correct on following month."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Even with a circulator running that boiler is probably drawing under 50 watts. If it ran for 12hrs/day that would amount to .6kWh per day. At the national average of 12 cents per kWh it would cost you 7.2 cents/per day or $2.16 per month in electricity costs.
It's not the boiler.....0 -
I'm thinking it has something to do with the wiring of the control panel. I plan on calling my electrician but I do need to look at my bill closely.0
Unlikely. After all, the power has to go somewhere -- and there's nowhere in that boiler for it to go.EricGill said:I'm thinking it has something to do with the wiring of the control panel. I plan on calling my electrician but I do need to look at my bill closely.
Do take a look at the bill, and figure out how many extra KW you are really looking at (not how many extra dollars, how much actual power). And then start looking around for where that power might go.Br. Jamie, osb
The electrician could measure the current draw on the circuits in your breaker panel.
Are there any small electric space heaters being used?
Maybe it’s the Pair of Teslas in the garage using all the juice.—NBC0 -
Dying to know the real answer to this one. That would be a lot of Christmas lights!!!0
Typical for meter reading date to varies a few days month to month, maybe more if a holiday/weekend. Check that bill for last month isn't for only 3 weeks and this one is for 5 weeks
Is it a single family home? Tenant tapping in maybe. Grandma's house was turned into 2apts, had a tenent tap into other apt's phone line when he wanted to make long distance calls.
What's your KWH usage for the month, if small some flood lights left on outside might do it0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
