First floor calls for heat boiler (short cycle) banging pipes
jogrady
Member Posts: 5
I changed the thermostat and replaced expansion tank which was full of water. The two other zones work fine. Could it be the zone valve is bad and causing this problem
It could. Could be a few other things, too...Br. Jamie, osb
Would you have a Honeywell zone valve installed backwards?0
You replaced the thermostat and extrol to remedy the problem? Sounds like it's air bound. How's the air eliminator(s)?0
Is the zone valve opening? Some have manual over ride.
Return valve closed or flow/check not opening?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
