First floor calls for heat boiler (short cycle) banging pipes
jogrady
jogrady Member Posts: 5
I changed the thermostat and replaced expansion tank which was full of water. The two other zones work fine. Could it be the zone valve is bad and causing this problem
    Jamie Hall Member Posts: 26,838
    It could. Could be a few other things, too...
  • JUGHNE
    JUGHNE Member Posts: 11,513
    Would you have a Honeywell zone valve installed backwards?
    HVACNUT Member Posts: 7,233
    You replaced the thermostat and extrol to remedy the problem? Sounds like it's air bound. How's the air eliminator(s)?
  • JUGHNE
    Is the zone valve opening? Some have manual over ride.
    Return valve closed or flow/check not opening?
