Zone balancing?
cnmdesign
cnmdesign Member Posts: 103
Do my four zones need to be balanced against each other or just the circuits in each zone?
Thanks
Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com
  • Gordy
    Gordy Member Posts: 9,546
    The circuits in each zone.
    cnmdesign
  • cnmdesign
    edited January 2018
    I have 24v Caleffi Z-one valves with two black and two red wire leads.
    The gauge is not mentioned in the spec sheet. I have a left over spool of four color phone wire. Can I use it or is the gauge to small?
  • Zman
    Zman Member Posts: 7,611
    Phone wire varies a bit in size. Some of the old ones would probably work. The newer stuff is not big enough.
    Albert Einstein
    cnmdesign
  • NY_Rob
    NY_Rob Member Posts: 1,370
    HD and Lowes carry proper 18 gauge T-stat wire in 2-8 conductor rolls.
    cnmdesign
  • cnmdesign
    A thanks to everyone for not starting out there reply with "Have you done a heat loss calc. :smiley:
    rick in AlaskaGordyCTOilHeatZman
  • HomerJSmith
    HomerJSmith Member Posts: 2,710
    Phone wire is 24 gauge, use 18 gauge thermostat wire. Phone wire that is four conductor and not Cat 5 phone wire has a color code of red, black. green, yellow.
  • Rich_49
    Rich_49 Member Posts: 2,785
    LMAO . Have you calculated the head of each zone ?
    732-751-1560
    Rich McGrath 732-581-3833
    Gordy
  • Gordy
    @Rich brings up a valid point for proper circulator sizing. If not heat loss then head loss :)
    Rich_49
