Zone balancing?
cnmdesign
Member Posts: 103
Do my four zones need to be balanced against each other or just the circuits in each zone?
Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com
I have 24v Caleffi Z-one valves with two black and two red wire leads.
The gauge is not mentioned in the spec sheet. I have a left over spool of four color phone wire. Can I use it or is the gauge to small?Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com0 -
Phone wire is 24 gauge, use 18 gauge thermostat wire. Phone wire that is four conductor and not Cat 5 phone wire has a color code of red, black. green, yellow.0
LMAO . Have you calculated the head of each zone ?cnmdesign said:A thanks to everyone for not starting out there reply with "Have you done a heat loss calc.
You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331
