What are these items connected to the attic tank?
egflyer
Member Posts: 3
See pics below. These are connected to the pipe leading to the tank in the attic on my gravity hot water system
Here's a great link for the info:
https://forum.heatinghelp.com/discussion/103712/gravity-system-with-honeywell-heat-generator0 -
Quit yelling Paul . LMAOYou didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Thanks to all
Mystery solved0 -
No mysteries here, just things we don't understand...yet.0
THE most important thing you need to pay attention to is the fact that there is Mercury involved. If you spill it, recovery will be at your expense, and it gets VERY expensive. And as others have noted, the mercury charge could have gotten blown up into the system, possibly in the expansion tank in the attic, or in radiators.
You'd be wise to make certain you have an insurance floater for hazardous materials. If not, get one. It's much cheaper than paying for recovery out of pocket.
Proceed with extreme caution, and if you spill some, DO NOT USE a vacuum to pick it up (it vaporizes into the air and becomes even more deadly). Scrape it together using business cards or playing cards, then recycle appropriately.
METhere was an error rendering this rich post.
Thanks Mark
I have no intention of disturbing it or removing it from my system. The system continues to work extremely well especially since I converted the boiler from oil to natural gas nearly 40 years ago.
My house is huge and was built in 1909. It has 10 ft ceilings and is 50 x 50 with three stories.
The original system was coal as evidenced by the remnants left from the bin and appears to have been converted to oil in the late 50s or early 60s.-1 -
Sorry, I assumed you were a contractor...
Excellent system.
That's not yelling, its digital stutteringRich said:Quit yelling Paul . LMAO
THIS IS YELLING!!!!!
ME
1
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
