top fed gravity hot water heating
leonz
Member Posts: 1,791
As much as I want to I cannot afford to buy the currently available AM Daniels 1928 first edition of Steam and hot water heating and I am hoping the fine members have pictures to share of top fed or bottom fed gravity hot water heating systems??
Have any of you used the two inch tapping's in modern boilers and expanded them to 4 inch pipe above the boilers steam chest using 2 to 4 or larger reducers for the up feed and return piping?.
Gravity hot water, I refer to every boiler having a steam chest :^0-0
Have you looked at the articles on gravity heating in the "systems help" section?Bob Boan
====================================================Ironman said:
Where would you find a steam chest on a mod/con?leonz said:Gravity hot water, I refer to every boiler having a steam chest :^0-
It would be for a coal stoker boiler with an H stamp that could be used for steam or hot water.
www.alternateheatingsystems.com
AHS S500, S1000, S1500 coalgun with (2 2.5 inch plus) supply tapping's and 2+ 2.5 inch return tapping's
The ASME H stamp can be purchased for an extra charge from Alternate Heating Systems.
Axeman Anderson S260 coal stoker ASME H stamp as standard offering with one four inch supply tapping and 2 two inch return tapping's.
- 15.8K Strictly Steam
