Boiler Mate
RayH
RayH Member Posts: 101
Any hints for why a Boiler mate hot water heater doesn't work ?
  • STEVEusaPA
    It's broke.
    unclejohnRayH
  • Grallert
    Grallert Member Posts: 1,037
    Pump, zone valve, control or the heat exchanger itself. There's a number of reasons. More details?
    kcoppRayH
    EBEBRATT-Ed Member Posts: 19,602
    pictures
    RayH
  • RayH
    I found a broken t-stat wire on the relay
    Grallert
  • rick in Alaska
    rick in Alaska Member Posts: 1,514
    I would have bet on the crappy digital control...
    Rick
  • HomerJSmith
    HomerJSmith Member Posts: 2,710
    Is the Amtrol Boilermate old or new. The older ones had a small heat exchanger with high head loss. But, you didn't specify why you think it didn't work. There is a boiler somewhere in the mix + a circulator + piping. It's just a storage tank with a heat exchanger. Can't get more simple than that.
    Gosh, maybe there is a valve closed somewhere.
  • HomerJSmith
    You mean a sensor wire that's disconnected?
  • RayH
    Thermostat wire in the Taco zone relay
