Boiler Mate
RayH
Member Posts: 101
in Oil Heating
Any hints for why a Boiler mate hot water heater doesn't work ?
I would have bet on the crappy digital control...
Rick0 -
Is the Amtrol Boilermate old or new. The older ones had a small heat exchanger with high head loss. But, you didn't specify why you think it didn't work. There is a boiler somewhere in the mix + a circulator + piping. It's just a storage tank with a heat exchanger. Can't get more simple than that.
Gosh, maybe there is a valve closed somewhere.0 -
You mean a sensor wire that's disconnected?0
Thermostat wire in the Taco zone relay0
- 120 Geothermal
- 394 Solar
