Drafthood does its job again
captainco
Member Posts: 844
A collapsed clay liner caused the carbon monoxide to leak into the building, because drafthoods are designed to allow equipment to operate with a plugged flue so there was no inconvenienced. I guess everybody was warm?? I question the inconvenienced part?? Wonder what would have happened if they had a barometric and a spill switch?? I guess they would have had no heat so they would have turned on their gas ovens for heat and got poisoned anyway.
Not sure how to attach the second link. Contractor in Wisconsin giving free CO checks and Alarms. I smell scam. There is a video that makes me cringe. A gas leak detector cannot pick up CO below 500 ppm to 2000 ppm. Is our industry that stupid?? But he is a licensed contractor (maybe).
http://fox6now.com/2018/01/06/it-was-well-worth-it-master-services-offering-free-carbon-monoxide-testing-for-your-home/
Pasted as a linkThere was an error rendering this rich post.
It's hard to tell if the news editor just butchered the edit job or if the company is testing for CO just using gas detector. Since there are only 2 tools present on the job, I would guess the latter."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
As soon as they stuck the inspection scope inside the heat exchanger, you know what their free inspection was hoping for and it wasn't CO.0
Some draft hood furnaces & many newer boilers have spill switches on their draft hoods.0
- 15.8K Strictly Steam
