Thermostat
daveamir
Member Posts: 69
Hi guys how's it going on NYC and I wanted to change my thermostat the picture of the current one is attached I wanted something that I could program for a lower night time temp and morning setback please let me know what you guys think thanks
Many people like the Honeywell VisionPro, which can use a remote sensor if needed.
In regard to setbacks, use a very small 3 degree at most, and see below:—NBC
https://forum.heatinghelp.com/discussion/164264/a-word-of-warning-about-night-setback-in-this-cold-weather#latest0 -
One thing to be aware of when it's very cold and windy is you could lose power. If you did lose power, better to starting the cool down from 70 than 63.
That may not be enough but it could just be enough to prevent frozen pipes.
3PSI gauge1 -
If the clock still works, then that old Chronotherm can do the job. Have a look at this video:
https://www.youtube.com/watch?v=R9xU33vfu8o
-1 -
Thanks guys0
My honeywell does a great job. I bought it a couple of years ago. Im sure you could find one on Amazon.0
Just don’t forget to wind it!—NBC0
I wind it once a week, it keeps excellent time. I am going to try and record a video of the setback sequence.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
