Furnace gas manifold
superD
superD Member Posts: 3
edited January 2018 in Gas Heating
Need help on how to remove Furnace gas manifold.
  • superD
  • superD
    EBEBRATT-Ed Member Posts: 19,914
    That's an old timer. What are you trying to do??
  • JUGHNE
    JUGHNE Member Posts: 11,527
    Pictures from farther back would be maybe better.
  • Tim McElwain
    Tim McElwain Member Posts: 4,658
    Pictures of the gas line just before the unit and taken further back would help.
    First of all shut of the gas and also make sure the pilot is shut off. The valve you are showing is a millivolt (Powerpile Honeywell gas valve). The number is probably VS-8187.
    Next look for the union that connects them gas line to the gas valve. Then after breaking the union look for what is holding the manifold to the equipment and unscrew or un bolt. It should then slide off the burners and you have the manifold in your hands.
    Now the million dollar question? Why do you want to do this what is your problem? How handy are you with wrenches and tools?
