2 Zone Taco Heating don't heat at the same time.
red1
Member Posts: 2
Hello - I am having a problem with my heating system. I have two zones and when one of the zones is heating up the other stops and vice-versa. Even though both thermostats say "heating" and both pumps are hot. We just installed the system 6 months ago and this is our first winter firing it. Not sure if the problem sits with the system, electric box (Taco) or thermostats. Thanks
Could be a few things. Can you get some pics of your current set up?You can have it good, fast or cheap. Pick two0
- 123 Chimneys & Flues
