Honeywell Pressuretrol Model for one pipe steam
Bruce_29
Member Posts: 9
What model Honeywell Pressuretrol and also model vaporstat should be used for one pipe steam?
For most one pipe steam systems, the standard pressuretrol will do, if properly calibrated and set as low as it would go. (0.6 psi cutin, 1 psi differential). The 0 to 4 psi vapourstat would give more precise control, but is probably overkill, considering the price.Br. Jamie, osb
Pressuretrol Model: PA404A1033
Vaporstat model: L408J10090
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
