Basement no heat
Bosco
Member Posts: 30
my basement with pipe hanging on the ceiling was change from that black pipe to that silver pipe(shown in photo), now I still feel the hotness of silver pipe but no heat coming out. Is it because pipe was change to that silver pipe which cause the heat stop comming out? Please advice, it bothers me so long.
1st fl and radiator has heat coming out. Basement just that pipe hanging on ceiling is hot but no heat.0
If piping was changed possibly air in radiators in the basement from draining the system to replace pipe. Bleed the radiators.0
Pictures will help0
This is the pic. I can feel the black connecting pipe has heat coming out, silver pipe has not heat coming out.1
Where does the silver pipe go? Radiator?0
Some more pics if you can. The boiler, and associated piping. Is there radiators in the basement?0
No radiator in basement. Basement rely on silver pipe to provide heat and it just hot n no heat. The silver pipe also connects to 1st fl radiator n there is heat.0
Take a look at the thread on radiator colour. Silver or metallic paints reduce the heat given off by any surface, and if it is mostly radiant (which those pipes were) the reduction can be as much as 10 times.Br. Jamie, osb
Paint it any low gloss (preferably flat) non metallic color. Look up emissivity.
METhere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
