Boiler pics.
Harvey Ramer
Member Posts: 2,281
I love love love the ability to pipe a radiant system direct to the boiler! It's great when that works out!
If the two big red radiant zones are not calling will the 2 or 1 small black zone be able to meet the min flow for the boiler? Or is that not an issue with the NTI?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
This boiler actually has built-in primary secondary piping within the boiler cabinet. Not that it's needed on this job.Solid_Fuel_Man said:I love love love the ability to pipe a radiant system direct to the boiler! It's great when that works out!
The 2 small zones are for the 2 bathrooms. They are controlled with straight-body TRV's. The one on the right has a direct mount operator. The one on the left has a remote mount control for the operator. They only get flow when one of the big zones call for heat. But, since the system is running an ODR curve, they get plenty of flow.1 -
What brand of manifolds are those?
P/M me and tell me your cost and sorce, please.Bob Boan
Ok with a little research I think it may be a Vmax153. So how much hot water do you think you are really getting? The problem many had when Triangle tube had a similar model (prestige excellence) was guys were mistakenly installing them where the customer had a soaker tub, and it ran out too soon. I saw the numbers on this Vmax and it seems impressive, just wanted real world numbersTom
Montpelier Vt0 -
@Tom
It is the VM153P. I can't really tell you about the real world hot water production. I only have 2 utility sink/tubs connected at this point. Reason I choose this one is for the small indirect built into the boiler. It keeps the boilers from firing every time someone washes their hands.
I would like to add something. This boiler requires a mixing valve on the DWH. I didn't put one in because they want the hotter water for washing misc crap in the utility sinks.
With the DWH set at 120, it produces 140 degree water for a while. Has to do with sensor placement I believe.0 -
I noticed the lack of mixing valve but knowing your work, I assumed the best and you confirmed it. How do you find jobs that allow such a clean room? Im stuck in every 1850s basement dungeon imaginable.Tom
Montpelier Vt0 -
This one was new construction. And since i was involved from the inception of the project, I was able to plan everything before the project even started. That was nice.Tom said:I noticed the lack of mixing valve but knowing your work, I assumed the best and you confirmed it. How do you find jobs that allow such a clean room? Im stuck in every 1850s basement dungeon imaginable.
I work in plenty of old basements as well
> @Paul Pollets said:
> Nice. 16 loops for 8000sf?
Yes. Some are spaced at 18" some at 15" and some at 1'. And the red tubing is 5/8", allowing for longer runs.0 -
I honestly can't tell you about the rust colored condesate. I noticed it as well.
What @Dennis said makes sense.0 -
> @john p said:
> Gorgeous job, well done. Love the red bracket for the expansion tank, as mentioned earlier.
> Only comment/question...why the reddish brown color in the acid neutralizer chips already, if system is brand new?
I talked to NTI about the condensate coloring the neutralyzer. They said it is perfectly normal with this boiler.1 -
Neat & squared away, soldier. Carry on! Great clean work Harvey. Mad Dog-1
The load center is right outside the door to the room with the circuit breaker for the boiler clearly marked.nicholas bonham-carter said:Nice professional job, and I am sure the client will show it off!
I would want the kill switch a little farther away from the boiler, however!—NBC0 -
so happy to see people understand high efficiency and the benefits to them and the environment, great looking boiler room,nice clean piping design, top notch work, wish more people in my area wanted systems such as this"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"-1
- 121 Chimneys & Flues
- 15.8K Strictly Steam
