viessmann wb1b-35 gas smell in cabinet
pumbaa
Member Posts: 8
in Gas Heating
its an internal leak after shut down. there isn't a leak in the gas train up to the gas valve0
just curious but what is tech support saying?
call a rep. last one that they had boiler replied and 2 weeks later the same problem with new boiler
sorry that should say replaced
thinking may be problem with venting???0
A gas leak is a gas leak. It is also an explosion waiting to happen. I don't want to read about you in the papers. Or on the 'net.
If you insist on living very dangerously, at least do your neighbours a favour and get the gas shut off to your house at the service entrance.Br. Jamie, osb
I had a bad gas valve years ago on a wb1a, was kicking out an odor. Glad you’re all set0
@pumbaa Hi there, yes years later, but I’m having the same thing at a customers house and im just wondering what you ended up doing? Just change the board or the gas valve as well? It’s almost 8pm here on a Friday so I can’t get tech support..0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
